I'm running into a problem with my 66321B DC communication source, although it could also be user error. When toggling the self-test error check, it returns error 0, which means that it does not detect any error. When I turn on the output with or without something connected to the output, it goes into OV PROT mode. If I disable OV protection it then instead goes into unregulated mode. I have been trying to use it via front panel or 14565B software and get the same result both times.
For anyone that owns a 66309, 66311, 66319, 66321 or similar source have you encountered a similar error?
