Author Topic: Revive dead Sony PVM-2130QM  (Read 4093 times)
Offline crt_cowboyTopic starter
Re: Revive dead Sony PVM-2130QM
« Reply #50 on: August 15, 2023, 07:59:53 pm »
I will check and provide an update. Even if the chance it can be repaired are very thin I would like to confirm where is the fault.
« Reply #51 on: August 16, 2023, 09:17:25 am »
I did some measurements with the isolation tester, look like the internal resistor of the tube failed open. Unfortunately there is no way to fix it.
« Reply #52 on: August 18, 2023, 10:50:47 am »
Just wondering are there some consumer TV with the same tube (A51JKQ10X) ?
From what I found online GVM-2020 and PVM-1960 might work but both are very hard to find.
Any other options?
