I agree with the post stating R552 is 8R2 ohms (8.2 ohms). Reading from right to left (as shown in OP photo) the bands should be gray, red, gold. The overheated area makes it difficult to see the gold band. The red band at the left end indicates 2% tolerance.
The resistor in the OP photo seems extremely small for a 1 watt rating. It could get overheated and discolored just by passing a large amplitude 20kHz signal through the amplifier. As recommended in the other post, replacing R552 with a 2 or 3 watt rated metal oxide resistor would be a good idea, and also replacing the original ceramic disc capacitor C528 with .047uF film capacitor rated at 100V or higher. This should be done on both channels.
I own the exact same model. Mine suffered a serious blow-up of one channel. It required replacing both large output transistors along with several resistors and small transistors. There was one small hole burned through the PC board. I was able to repair that. The other channel was undamaged.
I don’t recall replacing R552 or C528 in my unit. I’ll look at my amplifier and post photos of these parts.
I also have an original printed service manual. I’ll post relevant sections of the schematic as soon as I can.
My impression of this amplifier is that it is a simple but excellent sounding integrated amplifier. The video switching section is irrelevant these days because it only supports analog composite video (yellow RCA jacks). But it has everything else that a decent quality 2-channel integrated amplifier needs to have on the audio side.
Questions for OP:
1) Did this amplifier have any other burned or damaged parts other than this one resistor?
2) Is the amplifier working on both channels at this time?
