I am trying to repair an Air Condition PCB that burned a PWM (NCP1200), an N-channel MOSFET (IRFUC20 MOSFET N-CH 600V 2A) and two SMD resistors. Take a look of them in the attached photos.
So my question is :
1. Do does exist any schematic for this PCB?
2. In NCP1200 PWM datasheet for some projects suggests a >4.7KOhm resistor for pin8. Should I replace the burned SMD with that value? What values do you suggest?
