Hello guys
I have a Chigo AC and it is giving E1 error which on the label (Communication between indoor and outdoor unit problem). I noticed a smell coming from the indoor unit and after opening it I noticed the PCB had a toasted resistor which is on the Signal/comunication line.
I replaced the two components (the resistor and the high voltage cap next to it (just in case)) and inspected the outdoor unit PCB which appears to be perfectly fine.
Ran it several times, at the initial attempts no overheat was noticed but after trying couple of times the new resistor overheated again and all the parts in the resistor circuits appear to be fine.
Here's the photo of the newly installed components:
