Hello all.
New here. Glad I found this forum looking at the knowledge here. I usually work on guitar tube amps but took on the repair of a small Akai PA head. Symptoms were speakers cutting out. I looked at the speaker relay, suspecting it was the culprit but it tested fine. I tested a few points on the PCB where voltages were printed and notices the B+ wasn't stable. It was in-fact disappearing until so low that the relay opened and cut speaker power. The B+ then spiked back up, closed the relay and speaker functioned again.
So, I measured across the main filter cap. Voltage was rock solid, but if I place the negative probe on chassis ground, and positive on the cap, the voltage started dropping towards zero again. I'm at a loss as to where the voltage could be going. Would a leaky cap send voltage to ground? Any help would be massively appreciated.
AJS.
