Author Topic: Albrecht AE6490  (Read 1229 times)
Offline JaneTopic starter
Albrecht AE6490
« on: October 19, 2018, 10:28:13 am »
The CB Albrecht AE6490 has a problem with transmitting. Front panel  shows that Albrecht transmits yet, no output power on antenna connector.So I would guess power amplifier could be faulty. What voltage should I measure on output antenna connector?
In the schematic, there are also few test points but not given a proper voltages.One is marked as TP1 Driver. I expect it should be an output voltage of a driver block. Is it an input voltage for amplifier block?
What voltage is normal for that driver output?
Thanks
Offline CJay
Re: Albrecht AE6490
« Reply #1 on: October 19, 2018, 11:17:43 am »
Service manual is here:
http://www.cbradio.nl/abrecht/Service_Manual_Albrecht_AE6490_ENG.pdf
You won't be able to measure a DC voltage on the output, you need a dummy load, power meter or diode detector.
Re: Albrecht AE6490
« Reply #2 on: October 19, 2018, 02:14:11 pm »
Thanks for the reply.
Unfortunately the schematic does not give test point voltage values.
I know you are right but I do not understand the reason.
Is a modulation reason?
« Last Edit: October 19, 2018, 02:19:56 pm by Jane »
Offline CJay
Re: Albrecht AE6490
« Reply #3 on: October 19, 2018, 03:04:24 pm »
You don't need testpoint voltages, the collector of the final should be somewhere around 8V to 13V with no modulation but you will find it difficult to measure if there's RF present.
The reason you won't measure a DC voltage on the antenna socket because there should be no DC voltage on the antenna socket, there should only be RF which is high frequency AC, that's why you need the dummy load and a diode detector or RF power meter.
Does the front panel show power when you transmit?
Re: Albrecht AE6490
« Reply #4 on: October 19, 2018, 06:16:26 pm »
Thank you for the reply.
>the collector of the final should be somewhere around 8V to 13V with no modulation but you will find it difficult to measure if >there's RF present.
How to check that the final transistor( collector) is working properly and a problem is behind it?Or how to check that there is RF present or not ?With a scope?
Yes, the front panel shows power when I transmit.
Do you have any idea how to continue with a repair?
Thanks.
Offline CJay
Re: Albrecht AE6490
« Reply #5 on: October 19, 2018, 08:09:35 pm »
What test gear do you have?
Re: Albrecht AE6490
« Reply #6 on: October 19, 2018, 08:42:52 pm »
I have a power meter, dummy load, scope 200Mhz, digital multimeter
