Author Topic: I*really* want to remove Kester 44 flux - what do I need to buy?  (Read 2341 times)
Offline Psi
Re: I*really* want to remove Kester 44 flux - what do I need to buy?
« Reply #25 on: July 22, 2024, 08:47:24 am »
Heated ultrasonic cleaner and some proper flux cleaning solution intended for that purpose works the best.
It cleans well and takes ages to get saturated with flux, unlike IPA.
but it's not a cheap option
Online tooki
« Reply #26 on: July 27, 2024, 09:20:23 am »
I've found ethanol works better as flux remover compared to alcohol for cleaning up small bits of rework. But using real flux remover works even better but that stuff is in my shed for cleaning entire boards.
without knowing what "real flux remover" you are talking about,
|O  :palm: Geez, some people really need their hands to be held all the time.  It is simple: you go online to your favorite electronics dealer and order a bottle / can which says 'flux remover' after reading what kind of flux types the flux remover can remove.
I prefer trichloroethylene.
Which isn’t a “flux remover” product. It’s a single solvent. You can use it to clean flux, but “flux remover” as a phrase means “product made specifically for removing flux”.
Offline Coordonnée_chromatique
« Reply #27 on: July 27, 2024, 09:52:03 am »
Trichloréthylène, H350+H341+H319+H315+H336+H412= ?
