Author Topic: Alpine 3566 help  (Read 1294 times)
Offline DevcamTopic starter
Alpine 3566 help
« on: December 16, 2017, 05:01:48 am »
Hi my amp cycles on n off for a while before it finally settles to normal and works fine .i have changed power supply caps. Any suggestion thanks.
Sent from my SM-J320F using Tapatalk
Offline SMdude
Re: Alpine 3566 help
« Reply #1 on: December 16, 2017, 10:04:35 pm »
I have an amp that used to do that too(not an alpine though).
I sprinkled a bit of heat (with a hot air gun or solder station)about the place while it was turning on and found that when I heated up the really big caps in the middle of the amp board, it very quickly started running. I then replaced these caps, and just about every other electro for the hell of it as the amp is older than 25 years.
No more problems since!
