I counted around 48-50, and tried googling for said and nothing came up.Any further help would be greatly appreciated, thanks
Detents? If yes, how many?
I would try googling the product it came out of?
Buy a bog standard rotary encoder, they all work the same and are really cheap.http://www.farnell.com/datasheets/1837002.pdf?_ga=2.91571290.1764911387.1599678160-1771980843.1483642398&_gac=1.82231012.1599244606.Cj0KCQjwy8f6BRC7ARIsAPIXOjiAduvn9NAj5Ik0rGDp3u43Ww4Q0rjFBeeDwYnXOKyW2GQUczDMzwMaAo9aEALw_wcBIf you establish that this works as expected bodged into your circuit, then you just need to find a modern one that will fit and looks the part.(If it works backwards, you just need to swap 2 pin connections over)
