Author Topic: Alternative part? LG 6202VDT002S CRYSTAL  (Read 1052 times)
Offline ElectroWonderTopic starter
« on: January 23, 2019, 03:30:15 am »
Hello
Quick question:  I have an LG monitor with a faulty crystal. The crystal is not currently available from LG, with no firm ETA for availability.
I am wondering if any one would know of a suitable alternative?
The LG part number is 6202VDT002S
CRYSTAL.
Thanks in advance!
Offline Armadillo
Re: Alternative part? LG 6202VDT002S CRYSTAL
« Reply #1 on: January 23, 2019, 03:43:07 am »
Is it the type with the 4 pins?
2 of the pins are connected to Gnd
1 pin to Xtal in
1 pin to Xtal out?
Because you don't even provide photo of package? how to advice you?
But I think it's a 25Mhz crystal, most likely used by them in their 34UC.
The following users thanked this post: ElectroWonder
« Reply #3 on: January 23, 2019, 05:51:32 pm »
 Sorry, i dont have physical access to the part, to provide a pic.   It came from a 31MU97-B monitor. Ill see if I can get a pic of it.
Offline Armadillo
« Reply #4 on: January 23, 2019, 06:18:55 pm »
There are 2 crystals there. X200 and X300. Both are 12MHz crystal.
Who tell you crystal spoilt and part number?
You sure its crystal spoilt?
[Edit: Attached suggested part, you need to confirm thru-hole type or smd version]
« Last Edit: January 23, 2019, 06:23:25 pm by Armadillo »
