Author Topic: Metcal solder station parts  (Read 673 times)
Offline EvelhornTopic starter
« on: August 06, 2023, 10:08:07 pm »
Can anyone tell me where to find parts for Metcal stations. The port where the hand unit plugs in has some of the insulator missing. I have searched high and low to no avail. SP200 station.
Offline Shock
Re: Metcal solder station parts
« Reply #1 on: August 08, 2023, 02:31:45 am »
The RF socket? Show a few images of it on the PCB from both sides or if it's tethered from behind, as well as the front. I doubt Metcal supplies components to resolder into their stations and besides that it would likely be cheaper to get a good quality generic part (if possible).
« Last Edit: August 08, 2023, 02:47:17 am by Shock »
Offline Chris Jones
« Reply #2 on: August 08, 2023, 12:02:12 pm »
I think it's an F-connector - Does anyone agree with that?
Offline artag
« Reply #3 on: August 08, 2023, 12:12:08 pm »
It is on the MX-500. On other stations it's a DIN and a mini-DIN, so it depends on which one you have. Not sure about the SP-200.
