Author Topic: THS720A inverter board component identification required  (Read 1300 times)
Offline R_G_B_Topic starter
« on: June 17, 2016, 08:58:36 pm »
Can somebody tell me what this component is? see attached file it has an effect on how the THS720 increases contrast.
It should have a value around 5 ohms D.C resistance using the Peak atlas ESR.  But this one reads 27 ohms and effects the contrast e.g 75% contrast setting and you can see whats on the screen.
thanks
R_G_B
R_G_B
Offline dundee
Re: THS720A inverter board component identification required
« Reply #1 on: June 17, 2016, 09:08:41 pm »
I think it's a 0,10uf / 63V (Tantal?)Capacitor.
« Reply #2 on: June 17, 2016, 09:09:44 pm »
Yes its a capacitor I found the manufacture wima I just need to source the component.
Thanks
R_G_B
« Last Edit: June 17, 2016, 09:13:35 pm by R_G_B_ »
R_G_B
« Reply #3 on: June 18, 2016, 07:33:27 pm »
Looks like a polyester film capacitor. If you cannot get a SMD version use a 100n 100V leaded part there as a test.
Offline HighVoltage
« Reply #4 on: June 18, 2016, 07:43:01 pm »
Yes, that is a Made in Germany polyester film capacitor,
You can get it here
http://www.ebay.de/itm/151954925497
