Q1: Next to the volume control, there is a LED, what colour is it when you just power the sub ON without signal input connection? Wait for a while, does the LED change any colour?
Q2: Is there a switch "ON / AUTO / OFF" on your unit? If yes, put the switch of OFF mode, is there still any hum?
Q3: If you are able to open the sub, jumper the centre leg of the volume control to GND [not -15v, or +15v but the GND], is there still hum?
While you are at it, clean the volume control with contact cleaner like "DEOXIT".
Q4: Connect the sub to a proper input [from your receiver or whatever], is there still hum?, Are you able to control the intensity of the volume by the volume control?
