I got this at a boot Fair.It was fully working then.After about a few years it started giving odd readings?. When I looked inside,an IC marked U4 (see photo),a 4011 device had blue crystals around its legs?.I thought it was IC adhesive,or old flux gone wrong? It had corroded some of the IC pins,and PCB pads. I removed the original IC carefully as was possible,and replaced it with a new one. The meter now works,but gives random results and has about + or - 25% difference,when alternating the probes on a 3v battery. This fault is also reflected when measuring mains AC. I have also lost some of the button functions. I have looked for other possible faults ,like the rotary switch, battery,and fuse connections. I had trawled the Internet for a complete circuit without success. I know its an outdated meter , and should throw it away, but I like a challenge. Any Help Please? thank you
