Author Topic: An Electric shock from a new adjustable soldering iron  (Read 1345 times)
Offline DhanushkaTopic starter
  • Country: lk
« on: August 22, 2019, 07:37:15 pm »
Dear all,
I have brought this soldering iron. I got an electric shock after a one day. The voltage between metal part and home ground about 45 V/AC. But changing live wire to the neutral that was eliminated. There was no continuity between metal parts and live or neutral wires. Mains is 230 V/AC and it has two prong plug. Is this normal? How can I solve this?
Thank you.
« Last Edit: August 23, 2019, 04:03:50 am by Dhanushka »
Offline magic
Re: An Electric shock from a new adjustable soldering iron
« Reply #1 on: August 22, 2019, 07:49:19 pm »
Don't turn it on, take it apart :-/O
The following users thanked this post: Dhanushka
Offline TimFox
« Reply #2 on: August 22, 2019, 08:35:28 pm »
If connected to 100 to 120 VAC, this is typical for a capacitor network at the line, with no “PE” ground connection to the exposed metal.  Are you running with a two-prong outlet and an adapter, with no third-wire ground?
  • Country: lk
« Reply #3 on: August 23, 2019, 04:02:52 am »
The mains is 230 V/AC and this has EU two prong plug.
Offline TimFox
« Reply #4 on: August 23, 2019, 04:24:30 pm »
Then, to be safe, it needs to be double-insulated.  However, if it uses a temperature servo with switching from the line, it should have an EMC filter and that raises the grounding question.
Offline David Hess
  • DavidH
« Reply #5 on: August 23, 2019, 05:22:45 pm »
That is normal for a two prong device where the neutral is swapped with hot.  High impedance multimeter measurements can be deceptive because of capacitive coupling.
The following users thanked this post: soldar, Dhanushka
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #6 on: August 23, 2019, 06:05:15 pm »
1st 2 pictures is the circuit, before the ground wire mod (cable changed to 3 prong). the next pictures is mod suggestion, (heat shrink tube, spring for easy contact needed) make sure ground wire insulator will not get burnt by the heat and hence possibly get shorted with offline circuitry. so ensure your house's GFCI/RCCB is working properly. i used normal wire in the pic because i dont have heat resistance rubber wire.
