I'm just starting to restore what appears to be an Australianised version of the 375. The installed power transformer is an AWA 1L560543, which is the same power transformer as used in the Australian AWA Voltohmyst 1A56074. Apart from the power transformer, the internals are original OEM circa 1961-2 down to the B&K branded valves. Here's hoping parts haven't drifted, as the specs are still pretty nice except for the hassle of the chassis being grounded, which I will need to connect to AC mains protective earth in some manner unless I run everything off a 6V VRLA battery and use a dc/dc module for the 136Vdc supply.
That AWA Voltohmyst has effectively the same ranges and specs, but a combo meter fascia without the nice drum scales, so it will be interesting to see what the subtle differences are in circuitry.
