Unfortunately I haven’t had much time to devote to the scope but I have come up with a bunch of questions.
First I’d like to make sure that my understanding of the voltage multiplier is correct. I’ve attached a drawing of what I think a fourfold one should look like. All the voltages are normalized to the peak of the input AC. They only apply in a steady, unloaded state. Everything is referenced to ground at the bottom left except the voltages across the capacitors.
It seems to make sense but please tell me if I made any mistakes.
The main reason I started doubting myself is that in the schematic of the scope the input peak is 1.5 kV and the output is 7 kV. But 4*1.5kV is only 6kV and losses haven’t even been considered. And we know for sure that the input is 1.5 kV because the same winding of the transformer is rectified with a diode to obtain the -1500 V rail.
If you know how this could be reconciled, please share your knowledge.
About the implementation:
I’ve got a multiplier from an old color TV. It is almost certainly like the one described here:
http://www.kronjaeger.com/hv/hv/src/tv/If the D and focus connections are not used, it is a fivefold multiplier like shown in my second drawing. 5*1.5kV = 7.5kV minus the losses is much closer to the nominal 7kV. On that note, how tolerant are CRTs to variations in the acceleration voltage?
Another solution is to build one myself as suggested by shakalnokturn. In this case I have questions regarding pretty much every part of the circuit.
Diodes
Is it ok to connect several 1kV diodes (say uf4007) in series to create a hv diode? My intuition is that it should work fine. If one of them has a higher resistance than the others, its operating point starts advancing in the knee of reverse breakdown. This makes its resistance go down and basically regulates the voltage sharing.
Capacitors
Connecting them in series to increase the voltage rating seems a bit more risky. If one of them exceeds its rating even for a moment it will likely be damaged.
Insulation
The circuit needs to be potted to prevent arcing, corona discharge and to make it safer. What kind of potting compound do you recommend? So far I’ve only got two candidates that don’t exceed the budget of the repair: candle wax and tar. Though I’m not sure if their use is a good idea.
TL;DR
How sensitive are CRTs to higher acceleration voltage?
Can you connect diodes or capacitors in series to make a high voltage one?
Please recommend affordable potting compounds.
