Author Topic: Analog Oscilloscope vertical cahanels linked  (Read 2502 times)
Offline darkness_electroTopic starter
« on: August 17, 2015, 09:52:55 pm »
I have a problem with a tesla bm 566 oscilloscope. It had some z amplifier problems, but i sorted it out (partially). Now i have another problem. Channel a and b seem to be linked together. The position controls from a changes the position of b and vice versa. Also, when i apply both cannels is seems to sum them up. Also, both seem inverted. Moreover, it doesn't go all the way, meaning it cannot be calibrated. I apply a 4 volt signal p-p and it only goes to max 3 divisions (1v/div)  When i apply a positive voltage the beam goes down. Do you have any idea how to sort this out?
Offline tautech
Re: Analog Oscilloscope vertical cahanels linked
« Reply #1 on: August 18, 2015, 03:18:12 am »
Invert and/or Add functions enabled?
« Reply #2 on: August 18, 2015, 02:46:42 pm »
No, they aren't, but they use ganged switches and are on a quite inacessible board. Can they be internally shorted?
Offline tyguy2
« Reply #3 on: August 18, 2015, 02:51:18 pm »
That sounds like a likely cause. Try testing the continuity on the switches. You may also have an issue with the scanning on the CRT.
[Sarcastic comment] clever joke [/sarcastic comment]
Bitcoin:
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
Offline mikerj
« Reply #4 on: August 18, 2015, 02:59:04 pm »
Try giving the switches a squirt of contact cleaner followed by a good workout to remove any contact oxidation.
« Reply #5 on: August 18, 2015, 03:33:15 pm »
i tried wiggling the switches, but it doesn't seem to be working. also, in alt or chop mode i still have only one trace.
