A while ago i bought a Siemens "Oscillar". It worked fine for some time but one time when i turned it on the magic smoke escaped
. This wasn't ordinary magic smoke however. It literally smelled like sh*t.
So since it wouldn't do anything i suspected a Power supply fault, and sure enough i measured a dead short across one Cap, which took out a Selenium rectifier (see picture 1). It didn't have any blow marks on it, but my knowledge on chemistry was enough to know, that selenium is able to stink horrifically. So i replaced The cap (with 2 caps in series, with balancing resistors) and all of the rectifiers, since i didn't want the horrible smell again if another one failed. Doing this however is easier said than done, since one can't just mount different components on a PCB, just because there isn't a single PCB in there. So i glued the rectifiers to the case, where the old ones were. The caps i culdn't just glue in place, so i 3D printed a hold down plate and secured it with a zip tie (Picture 2 and 3). And voila it works again.
I just posted this here, because I thought some people might find this interesting.
