Author Topic: Anker 24W 2-Port Turbo USB car Charger (71an2452CS) replacement fuse  (Read 3067 times)
Offline NeurotoxTopic starter
Hello,
I'm trying to repair a Anker usb car charger.  From what I have check so far, the fuse has blow.  I try to figure out what is the correct spec to buy a new one but I'm lost...
Model of the charger: Anker 24W 2-Port Turbo USB car Charger (71an2452CS)
Input rating: 12-24V
Output: 5.0V, 4,8A
The fuse is a white surface mount and have only a "V" on it.  You can see it in the picture.
Any way I can possibly identify it ?  I'm tinking about contacting Anker...
Thanks!
Re: Anker 24W 2-Port Turbo USB car Charger (71an2452CS) replacement fuse
« Reply #1 on: July 07, 2017, 05:30:48 am »
I'm answering my own question ;)
Apparently they seems to have no easy way to find back what was the value of a surface mount fuse from what I have read and it make sens...
https://electronics.stackexchange.com/questions/35816/replacing-smd-fuses-without-access-to-schematics
Let's try with the manufacturer...
Offline OiD
« Reply #2 on: July 07, 2017, 11:03:11 am »
Look on the outside of the device, it should tell you the max current the device consumes. if its a 24W charger and its 90% efficient lets say it consumes 27W on average and the V*I on the label gives 35W find a fuse that can handle fast peaks for the 35 and a small margin for the 27W.
Or play it safe with a fuse to supply 24W of power and see if it works. Fuses normally blow for a reason so you might replace it and it could immeaditely blow again. You'd need to find the cause and fix it.
Offline Armadillo
« Reply #3 on: July 07, 2017, 11:11:48 am »
Could be 6.3A;
Just measure the size whether its a 1206 device.
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #4 on: July 07, 2017, 08:25:44 pm »
Could be 6.3A;
 :-DD
« Reply #5 on: July 13, 2017, 02:56:43 am »
Update:
Of course Anker did not want to give me the information...They strongly suggest me to stop trying to repair it for safety...  ;)
But they answer really fast and even send a new unit.
