I have yet another oddity, a multimeter that only turns on if you shake it.
It works until jostled of moved but upon either it has to be shaken to make it work again, i checked the line cord, the fuses, the switch and there is voltage going to the transformer but for whatever reason it will not turn on regularly.
When it won't turn on the only thing to do to make it turn on is to shake it.
I seem to attract weird problems, either that or i don't know enough yet. Any suggestions for this one? Please and thank you.
