I've been looking at posts on the old Tek 212. My intention was to remove the long dead battery packs to guard against leaking but now it looks like I may have a repair to do. First, I need to determine if the dead batteries or removing the batteries could result in the attached wonky waveform (no input)? Are the batteries performing a filtering function under normal circumstances? Could they be replaced with some electrolytics if I don't intend to use it battery powered? If not the batteries, do you agree that a problem exists in both the horizontal and vertical circuits or before? Traces don't normally fold back on themselves! I did get my hands on the service manual, and I do intend to DEox all of the contacts. I'm looking for a knowledgeable hint from you guys for the best way to start. Perhaps someone has seen this situation before? TIA Rick
