Author Topic: Another wonky 8050A (not LCD related)  (Read 1301 times)
Offline BlastcapTopic starter
« on: January 30, 2017, 10:55:46 am »
Yay.. another 8050A  :horse:
I've had a 8050 for a while, and its been annoying me for a while.
The symptoms are:
When switching between measurements modes it very often sticks in dB mode, and after a few tries (switching between two modes) i gets it to stay in the right mode.
When measuring the reading ... kinda freezes, it stays at a value and slowly decrease (1 count/s), even going into negative. Example: I measure 05,210V in (20V range), takes the probes away and it stays at 05,210V, then decrease at a rate of 00,001V/s. Shorting the probes does nothing, changing rage or mode, usually leads to Symptom 1.
Does anyone have any ideas, or cleaning advice that could help?
Offline retiredcaps
Re: Another wonky 8050A (not LCD related)
« Reply #1 on: January 30, 2017, 06:41:19 pm »
Maybe deoxit
