Hey guys,
Few months ago i bought an AXIOMET 3005 DS power supply and it's great. The problem is that now it shows 0.5 Amps current draw when nothing is connected to the output.
After 1 month of moderate usage, it began to show 0.03 A under no load, then it was showing 0.120 A under no load and now shows 0.5 Amps.
If i connect a load that draws more than 0.5 amps, let's say 1.3 Amps, it shows the right value, but after i remove the load goes back to 0.5 amps in stand by.
The voltage reacts ( goes down) if i turn the CC nob to zero.
I had some short circuits on the output couple of times, but it has protection. Maybe this may have damaged the sensor ?
Is there an easy fix for this ?
Thank you
