Author Topic: apollo twin x short circuit  (Read 579 times)
Offline UserliTopic starter
« on: August 08, 2023, 01:40:31 pm »
I received a broken apollo twin x for possible repair and quickly found the device shorted at the 12V input socket.
Investigation shows that a component (see image) connecting 12V and GND is shorted. I assume this to be an input protection device but can't find any info about it. Does anybody know, what this is?
Offline fzabkar
Re: apollo twin x short circuit
« Reply #1 on: August 08, 2023, 05:16:58 pm »
It appears to be an SMAJ14A unidirectional TVS diode made by Vishay (General Semiconductor).
https://www.vishay.com/docs/88390/smaj50a.pdf
« Last Edit: August 08, 2023, 07:46:41 pm by fzabkar »
The following users thanked this post: Userli
« Reply #2 on: August 08, 2023, 05:58:59 pm »
That's indeed the most probable and I ordered this one now. I assume though, it's some kind of Chinese clone, since the marking doesn't fit.
Offline fzabkar
« Reply #3 on: August 08, 2023, 07:22:39 pm »
It's kinda the same ...
https://www.aliexpress.com/item/1005003667874457.html
The logo belongs to General Semiconductor which was acquired by Vishay.
BTW, it's unidirectional, not bidirectional as I originally wrote.
« Last Edit: August 08, 2023, 07:47:24 pm by fzabkar »
Offline benj38
« Reply #4 on: August 08, 2023, 07:35:02 pm »
What part of the marking seems wrong to you?
The part number code "XK" is exactly what the datasheet specifies, and the logo seems fine as well.
« Reply #5 on: August 08, 2023, 07:48:13 pm »
You're right. I looked at the SMC package version, which has a different marking.
