Hi Mark,
Yes, I know of the snap on battery. Keeping my fingers seriously crossed for that, but not sure. I will have to open the VNA to check. I have a picture, but can’t tell from that. This seems to be Motorola decision, by the look of their board, by the way. ... but yes, what were they thinking?
Nevertheless, I would so much like to download the content of the BBRAM so that I stand a decent chance of restoring the machine, should anything go wrong. I read in this thread about using a debugger and a serial port, but don’t see how that can be done. The cpu is a MVME162 so there should be software around or even better, installed.
There is no serial port on the vna so is there one on the cpu?
Just don’t understand if a broken BBRAM will cause the board to brick itself even more or if it’s possible to get it running again with an OK BBRAM?
I read also about boot code. Is there a special disk supplied with the MS462? The 37247 doesn’t seem to have anything like that. Would very much like to get hold of the boot FW inside the VNA to examine. Is this on a regular eprom somewhere? Likely not a dip? Would like to get that to perhaps examine. Notice the thorough work by djac and would like to give it a second shot.
Many questions. Perhaps several are obvious, but I have never had to deal with this before (although heard about it and - so far - happily realized it doesn’t concern me - so far that is...).
Regards,
Staffan
