Does anyone have any info on the LEDs on the motherboard or the boot process for these units? Should I just be referencing the materials from the board the CPU board is based on?
I've got one with similar symptoms that just lights most of the front panel lights and doesn't do anything (nothing on screen, nothing on external screen, nothing on RS232), and I've replaced the snaphat, the RTC battery, and copied the contents of the U75 ROM, but I haven't gotten any farther in the process yet. The four LEDs on the board light and then go out very shortly after boot, and when a keyboard is attached, the caps lock and other lights flash like a normal boot, but nothing else (and no activity light flash on the USB port that's in the place of the 3.5" floppy on most units). When the U75 ROM is pulled, the four CPU board LEDs light and don't extinguish, so I think the process is at least getting to reading or preliminary checking of the ROM, but I have yet to find signs of light beyond that.
I've tried holding the 1 key on the front panel to try an boot from an alternate source, but again no activity on the FDD replacement LED and no difference on the board (since there's a beeper on it, I would have expected that or LEDs lit if there was a CPU/memory error). I will see if the linked disk utilities will work on a USB stick in this unit, but since the floppy described doesn't sound like it's bootable, I don't know if my unit will even get far enough through the sequence to try to boot from something.
Is the BBRAM with the fresh snaphat to blame for preventing the boot altogether, or is my unit hanging before it gets to that stage?
