I have recently acquired an Anritsu MG3700 having the rubidium clock option but unfortunately there is something wrong with it. The frequency is not steady. I don't mean just not as steady as one would expect a Rubidium oscillator to be but unsteady like a simple LC oscillator would be better.
It goes in cycles, the frequency slowly rising from about 20kHz below its intended frequency of 10MHz and as soon as it gets to within about a kHz from where it should be it suddenly drops back to -20kHz and keeps repeating. Each cycle takes several seconds.
I am checking the frequency on the 10MHz reference output at the back of the instrument. I don't know if the actual rubidium oscillator itself is faulty or the PLL and whatever other circuitry it uses to bring the frequency down to 10MHz. I'll be trying to find out but would appreciate any advice beforehand if anyone can help. , perhaps having seen this problem before. I think checking the module itself should be quite easy, I just need to look for a pin with the ~6.8GHz on it and see if first of all if there is any signal at all and secondly whether it is stable or not.
If I apply a good 10MHz to the reference input, bypassing the internal reference, the the instrument works perfectly, so the automatic reference clock selection and subsequent use of the reference works fine. I am in fact using the instrument only with external clock.
I took apart the reference clock module and found it has quite a lot of bodges. I don't know if these are an attempted failed repair or an official Anritsu bodge to fix some design issue. The bodges are on the support board, not the Rubidium module itself - I didn't open that and don't intend to unless I am sure it is faulty. I would really like to fix it as part of the reason I bought this particular instrument was the rubidium clock.
I have attached pictures of the reference clock module, with the RF covers removed.
