While I know nothing about the unit itself, given that it is an optical spectrum analyzer, it needs a diffraction grating and a slit (probably adjustable) to disperse the light onto a CCD for analysis. The slit-1 error likely means that the slit is not behaving correctly. Given that it is just a simple slit, I would venture to guess that the driver that controls the slit has a problem, or maybe the optomechanics that adjust its width are malfunctioning in some way
