Author Topic: Planned Obsolescence - Dynamic Obsolescence  (Read 781 times)
Offline SilverSolder
« on: January 20, 2022, 12:48:05 am »
Interesting video from Veritasium...   Nothing new under the sun, planned obsolescence has been with us for around 100 years...
Offline whatboy
  • Country: mx
Re: Planned Obsolescence - Dynamic Obsolescence
« Reply #1 on: January 20, 2022, 06:57:05 am »
Clearlly shows you, there are evil people who just care about money, and nothing else...
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #2 on: January 20, 2022, 07:16:03 am »
… vs Poor Design,
Don't ask a question if you aren't willing to listen to the answer.
Online Kleinstein
« Reply #3 on: January 20, 2022, 09:09:03 am »
For the light bulbs the temperature of the filament effects the lamps lifetime and the efficiency. So while it is possible to make light bulbs that last longer, they would also consume more power or give less light. The 1000 h life time may be a reasonable compromise between the costs for a new bulb every now and than and the costs for the electricity. In later times with the cheap bulbs the 1000 hour bulbs were likely a little on the cold side and a bulb running hotter and lasting only 500 hours may have been more economic.
Getting a standard for the bulb life, made the bulbs more comparable and this way even helped competiotion and consumers. So while they may have had bad intentions - the result was more like a good thing.
The following users thanked this post: I wanted a rude username, Haenk
Offline HighVoltage
« Reply #4 on: January 20, 2022, 09:23:15 am »
Eastern German light bulbs and those from other east European countries lasted 5000 h or longer. Only the West had the cartels to regulate the lifetime of a light bulb. I think this is not a conspiracy anymore and has been proven fact for many years.
« Reply #5 on: January 20, 2022, 04:47:21 pm »
Interesting how the "fashion" aspect is referred to as "dynamic obsolescence" lol.
Is that why Keysight's new instruments are black, vs. the previous white ones?  (No prizes for guessing, LOL)
Offline whatboy
  • Country: mx
« Reply #6 on: January 20, 2022, 10:39:18 pm »
It is also well known that printers and bateries have a counter, when it goes to zero, it is gonsky! even if there is still enough life on the devices!
« Reply #7 on: January 21, 2022, 06:41:42 pm »
In fact, Canon was charged in a class action lawsuit, for disabling all the functions of a multi-function device when the ink ran out, e.g. it could no longer be used as a scanner because it was low on ink!  :D
Lucifer himself will be inspired to innovate and create a completely new level of experience in hell just for the geniuses behind these kinds of ideas!
