Hey beginner electronic hobbyist here,
My Ansmann Energy 8 battery charger stopped working some time ago, I opened it to see if it's just a bad cap or if something is blown.
When I plugged it in I noticed that the switching power supply is making a 2hz ticking/chirping noise , I figured its the power supply trying to start. To see if there is a short either in the power supply or in the rest of the circuit I desoldered the PSU and it was still ticking, so I figured the fault must be there, buuut after some trying and soldering to find the fault, I plugged it in and the PWM switch blew up in smoke
(maybe it was broken from the start and I just gave it the rest? The PCB under it was darkened)
This is the part where I should probably get some help, I figured I should replace the PSU entirely instead of replacing the TOP223Y PWM switch and most of the other components because there's still a fault in there somewhere.
Can you please help me figure out what voltage outputs this PSU has so I can replace it?
high resolution pictures(btw. I wasn't sure if this belongs in Repairs or Beginners, I hope it's right here)
