I have one, and gave up on using it to program GAL22V10's. It ruined several of mine to the point where
they were un-erasable, while others were fine. Some people report no problems at all, others report
the same, which leads me to conclude it is one or all of:
- The SW has data-dependent bugs,
- The SW doesn't/can't handle minor process variations (22V10A vs. 22V10D vs. etc)
- The HW has subtle voltage/timing issues
There's probably a good reason DataIO had close ties with vendors and issued updates far more
frequently than Autoelectric can.
I got a Wellon VP299, which is a lot more expensive than the TL866, but it hasn't given me problems yet and
it was cheaper considering how many 22V10's I wasted.
So, rant aside:
1) do you have access to any other devices, particularly DIP w/o an adapter needed, that work
when programmed?
2) Is the USB cable decent?
3) Reading the ID value requires high voltage, you mentioned VDD was noisy but what about 12V?
