The general design is a sleeve on the wire on the right AMP 16-14 - 2.5mm crimp, which should hold the wire. broke after her.
The wire enters one cartridge holder and exits from there to the second. glued in the middle.
The size of the occasions inside, for further repairs.
The first disassembled sleeve where two wires come.
inside, a 22µH inductor and a 270pf capacitor, which are connected in series on one side, are soldered to the outer conductor of the bushing and the signal core from them goes to the second cartridge.
the central core without mass comes from the incoming cable. The total mass of the braided cables is soldered on the outside, to the lug on the back.
location of the insulation. heat shrink isolates the LC circuit from the central core.
The second cartridge - I already wrote that it has a slightly different design, since it regulates the convergence of the tweezers. on the first - adjustment back and forth. When disassembling, it is better not to twist the slot - then the sleeve will not be put on. very precise fit.
After a little violence - we get access inside.
Everything is simple here - the core comes to the center, the braid is soldered onto the outer sleeve.
the clamps that hold the adjusting screws are removed by knocking out the axis. it looks like a rivet, but it's not a rivet.
assembly is a little more complicated - since it is necessary to assemble with the wires wired in place.
