Hello all,
New member here and joined after reading some of your welder repair posts.
In order not to pollute this space too much, I'm adding a link to my post in the diysmps forum. The admin there was helpful with some comments, but I'm asking for more help here. I you deem it better I can transfer it all to here.
Basically I blew up the welder using an under powered, cheesy generator that alsmost stalled. The saga is here...
http://www.diysmps.com/forums/showthread.php?697-SMPS-Failure-Analysis-and-Repair&p=11808The schematics for the welder are referenced there, but I add the links here also...
Schems are here,
My welder 160 amp
https://dl.dropboxusercontent.com/u/85561940/th160.pdfComponent placing FWIW,
https://dl.dropboxusercontent.com/u/85561940/thcomp.pdfSame welder more less but in 200A version
https://dl.dropboxusercontent.com/u/85561940/th200.pdfMy first request here is feedback on whether my thinking as to why it blew up is on track. After alot of reading, and getting a handle on how smps work, this is what I think happened..
My thinking is the extreme under voltage/brownout when the generator almost stalled dropped the +-15 ac voltage coming out of the transformer which then gets regulated to +- 15 volts for gate drive, and then regulated again to +-12 vdc for for the control circuitry. With this low voltage the control/pwm gdt drive etc stopped working and the igbts stayed on and fried.
Or the +- 15v gate drive was too low to switch the igbts off.... or too high whhen generator was overvoltage and exceeded the 20v gate-emmiter limit. and cooked the device.
Once this happened the short sent 300vdc across the gdt secondaries.
After this replacing parts (IGBTs, bridge, fuse etc.) w/o replacing the open GDT it would still blow up (which it did) due to open g-e circuit, since the GDT was now open.
my thoughts, comments welcome,
regards,
nick
