Author Topic: Please help with identifying/troubleshooting this transistor  (Read 769 times)
Offline highcapTopic starter
This is within an 91' CRT monitor (dumb terminal)
It is having a copper radiator, but it's running very hot like you can't touch it (unlike the other similar transistors on the board), in just 2-3 minutes after powering up.
My issue is this is within a terminal monitor, so the terminal board underneath seems to switch itself off and no more text is displayed on the screen, within about 1 minute since powering up the monitor. (The more it stays powered off, the more it can hold on at the next power up, and the opposite)
Also, I can't find any info online about this transistor by its marks, it might be the culprit?
Thank you for any help!
Offline watchmaker
  • Self Study in EE
    • Precision Timepiece Restoration and Service
Regards,
Dewey
The following users thanked this post: highcap
Online fzabkar
Re: Please help with identifying/troubleshooting this transistor
« Reply #2 on: June 07, 2024, 01:12:36 am »
91 feet? :-)
Can you show us a photo of that area of the PCB? Do you know what the circuit is doing in that area?
The following users thanked this post: tooki, highcap
Offline Whales
    • Halestrom
« Reply #3 on: June 07, 2024, 01:26:48 am »
Where is this transistor in the circuit?  What does it do?  Can you provide photos of the circuit board?
The transistor overheating is probably a symptom, not a cause.  Something elsewhere might be bad.
« Reply #4 on: June 08, 2024, 11:17:11 am »
91 feet? :-)
From year 1991 :)
I'm accompanying this post with a pic of the terminal board underneath and more CRT board pics.
Note that the CRT tube remains powered on after the text is disappearing, it seems there's an issue with powering up the terminal board, but maybe I'm wrong...
Thank you for your inputs!
« Reply #5 on: June 08, 2024, 11:23:47 am »
And just added a video with what's actually happening.
To be more precise, I have also measured voltages of the DB15 out connector from the CRT board to the terminal board, and it seems like some voltages are progressively dropping (since powering up) from 5.12 volts to around 0.3 volts. That may indicate a power issue on the CRT board that needs to sustain the terminal board.
https://youtu.be/4CZuLlBMe_o
Online tooki
« Reply #6 on: June 08, 2024, 05:25:50 pm »
91 feet? :-)
From year 1991 :)
The apostrophe replaces the omitted letters or numbers, so 91’ would be “91nnn”, where nnn is any number of digits — it cannot mean 1991. In other words, to abbreviate 1991, you need to write ’91. Or just write 1991 to make it clear it’s a year — it’s literally only one more character!
« Last Edit: June 08, 2024, 05:27:41 pm by tooki »
« Reply #7 on: June 08, 2024, 07:54:22 pm »
True, I was too focused on the issue I placed the apostrophe the other side.
Offline kevin.gibbs
    • Teardown it!
« Reply #8 on: September 18, 2024, 11:23:16 am »
Looks like the transistor power is not enough for a monitor with a diagonal of almost 30 meters )))))
Teardown, research, create!
