Author Topic: Anyone experience with Crown XTi amplifier repair ?  (Read 990 times)
Offline prutserTopic starter
« on: August 18, 2018, 08:15:29 am »
Somebody at Crown had a nice idea to save cost. They clamped 2 heatsinks on top of each other. To replace to power transistors the top
heatsink needs to be removed.   So far I managed to get 2 off, but needed to apply a lot of mechanical force, which I do not like ) and it took me about 10 minute
per heatsink.
Anyone experience with this amp and knows how to remove those heatsinks nicely ?
Offline Shock
Re: Anyone experience with Crown XTi amplifier repair ?
« Reply #1 on: August 18, 2018, 09:47:48 am »
per heatsink.
Not removed them. Some ideas though.
Getting them apart in place I'd try using a wide L shaped wedge tool with short edge and use slight fulcrum motion moving between spots to part the heatsinks. Google "paint can opener". The other is if you found something suitable to wedge into the gaps, a C clamp could be used to pry them apart.
From the looks of them though, compression would be required to reassemble.  Then I would say remove the whole pcb, then removing the heatsink assembly from the PCB would be the best idea as it seems the safest for reassembly.
