Author Topic: ITT GX240 Metrix Function Generator  (Read 863 times)
Offline Orion63Topic starter
  • Country: sg
« on: October 28, 2020, 01:54:04 am »
Hi, I have this ITT GX240 Metrix Function Generator with Frequency counter. It has developed a display problem as shown in the attached picture. All the functions are working alright. Even the digits are displayed correctly, except that the segments G,E and C does not illuminated on the display. I tried taking out the LCD module (40-pin) and cleaning the contacts but was not successful. Could it be a display driver issue or LCD issue  :-// ? I don't think it is Microprocessor issue as the data is sent correctly to the Display unit. Any help from the forum is appreciated. Thanks for looking.
Offline shakalnokturn
Re: ITT GX240 Metrix Function Generator
« Reply #1 on: October 28, 2020, 11:36:02 am »
To check the driver IC without schematics you'd have to scope all the outputs to the LCD, normal driving levels are (close to) 0V, (close to) Vcc, Vcc/3 and 2Vcc/3.
What can also happen with those LCD's is that one of the glass-metal "F" shaped contacts becomes loose.
Try applying some pressure to the LCD or contacts individually while it's working see if it makes any difference.
