Author Topic: Anyone here have experience with McIntosh solid state audio amps?  (Read 804 times)
Offline cvancTopic starter
...You know, the ones that have an autoformer at the output.
I've got one on the bench right now and I would love to hear what a reasonable reading might be for the autoformer winding resistance.  I assume they've got pretty beefy windings (this one is 300W per channel), so nominal winding resistance would be quite low.  But does that mean a couple ohms is normal, or a couple tenths of an ohm, or what?
This one reads lower than I think is correct (unfortunately).  All input welcome, thank you.
« Last Edit: December 04, 2017, 02:38:08 pm by cvanc »
Offline MomirPeh
  • Country: cz
Re: Anyone here have experience with McIntosh solid state audio amps?
« Reply #1 on: December 04, 2017, 02:45:19 pm »
Hello,
Well, if that amplifier is a stereo, then you should have two of them (one per channel), right?
You could measure the known good one and compare, unless both have shorted windings.
