Author Topic: AOC CM 312 monitor problem.  (Read 1186 times)
Offline AndersloberTopic starter
« on: November 15, 2023, 12:37:36 pm »
Hello forum. Just a quick question. I need to know the value of R750 and ZD750 on the crt board of this cm312 monitor. I cant find a good SM.
I hope to get some help. Thanks. See picture for position. Picture is from forum.
« Last Edit: November 16, 2023, 03:01:54 am by Anderslober »
Offline sean0118
Re: AOC CM 312 monitor problem.
« Reply #1 on: November 15, 2023, 11:51:14 pm »
Hey, I've attached the schematic I have, but the value for ZD750 is unreadable. Maybe 6.8V ?
I still have my Commodore CM312, so can open it and have a look this weekend  :-+
edit: 12V rail so the zener is probably 12V?
« Last Edit: November 15, 2023, 11:52:49 pm by sean0118 »
The following users thanked this post: fzabkar
« Reply #2 on: November 16, 2023, 02:59:36 am »
Wow…thanks for the great info! Highly appreciated if you can check too. 👍🍻 R750 is 75 ohm. Zd750 possibly a 12v zener.
The resistor and zener were both fried.
Offline PA0PBZ
« Reply #3 on: November 16, 2023, 11:00:02 am »
I think, looking at other commodore monitor schematics, that the zener is 93D39-68 which would make it 6.8V and that makes no sense on a 12V line  :-//  So 12V would be a good choise, probably the zener shorted and smoked the resistor.
« Reply #4 on: November 16, 2023, 04:31:02 pm »
Yes…I changed to a 12v zener and new 75 ohm resistor. I have power and crt elements are glowing, BuT, no life in display….ideas welcome….I have checked anode cap..all is good….still no display…..
The following users thanked this post: sean0118
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
« Reply #5 on: November 16, 2023, 08:34:11 pm »
If there is no beam at all, check the pre acceleration voltage. If that still checks out good, that must mean CRT is working. Or is it?
To check if the CRT will still even display any kind of beam, disconnect the wires to the electron gun grids. Manually drive the grids and see if a beam appears.
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
« Reply #6 on: November 17, 2023, 09:11:19 am »
Pre-acceleration voltage…..where exactly would I check this on this cm312 monitor? Does the anode cap transformer ever go bad?
Strange this…..
Offline sean0118
« Reply #7 on: November 18, 2023, 03:42:20 am »
I measured mine and get 12.7V across the zener so your replacement should be correct. Resistor on mine is also 75ohm.
I'm not sure if my CRT is fixed (I need a CGA card to test) but I do get a raster with no input connected. Let me know if you want me to measure any other voltages for comparison.  :-+
« Reply #8 on: November 21, 2023, 06:41:45 pm »
Strange this…..
I wouldn't know for this exact CRT monitor without the service manual, but you can try finding the pin to measure from by looking at the electron gun construction.
