Author Topic: AP 2722 show error (8070) : dsp host vector not available  (Read 444 times)
Offline blueangelTopic starter
  • Country: tw
« on: June 15, 2024, 06:28:42 am »
Our 2722 show error (8070) :dsp host vector not available. If it possable I can fix it myself ? Seem no service manual can reference.
Does some one can help ?  I already check all power supply are normal ,and connect checked also. But I don't know DSP HOST VECTOR issue need to check which board.
Thank you very much.
  • Country: tw
Re: AP 2722 show error (8070) : dsp host vector not available
« Reply #1 on: June 21, 2024, 03:13:23 am »
Update....
I found that don't power on AP2722 , Run APP first , when screen show four items and wait for select, then power on AP2722 , and choise 2 or 3 or 4 , AP2722 will work. If choise item 1 ,same error message will pop up.
I don't know what cause it...
« Last Edit: June 21, 2024, 03:16:40 am by blueangel »
