Hey everyone. Found you on YouTube. Watched episode 504, tear down of an APC 2200 UPS. Figured this would be the best place to ask a question.
I came across an APC Back Ups 1000 Pro (BP1000) with dead batteries, and missing the panel switch/LED panel. I dropped in a couple batteries and plugged it in. Single beep, couple clicks, and a hum of the charger, charging properly. Checked various voltages here and there and everything seems ready to try. However, without the front panel, no on/off switch...
I have 118vAC up the main relay that turns on the outlets. I can't find any schematics for this unit, but the couple I have found for other models with a ribbon cable, make me think of the 8 pins, one of them is looking for a momentary GND signal to turn on. Before I just poking pins with GND, any recommendations for me? I figure if need be I'll build the serial control cable for it and try turning it on with my laptop.
Here's what I have found on the ribbon cable...
Pin 4 - GND
Pin 5 - 4.4vDC
Pin 9 - 4.9 vDC
Thanks for any help you can offer.
