Author Topic: APC SMT1000I display problem  (Read 1163 times)
Offline gameruTopic starter
« on: May 09, 2016, 12:11:17 am »
Greetings
Today i was scammed!I bought an APC SMT1000I,the seller told me the unit it is in perfect condition.When i received the unit i discovered the display don't work.I think the display is the only problem.I powered two light bulbs of 100W each.I measure the Voltage and is 228V constant,but on the display does not appear anything.
I tried to take apart the display from front mask,but it has too much clips.
Can someone tell me if can be repaired or where can i find parts ?
