Hey so I’m doing my 1st D class amplifier repair i purchased a Behringer NX3000D off eBay as faulty “dead on arrival” I spoke to the owner looks like he purchased a few of them and kept this one as a backup never used it he went to use it years later and one channel was in protect other channel made a bang sound though the speaker every time he turned it on he apparently did it a few times and now both channels are in protect I received the amplifier have not turned it on had a look couldn’t see any blown components I checked the Fets one fet is shorted across Gate drain and source rest of the fets read 5v on diode mode on my multimeter I tested every transistor resistor capacitor and diode after the drive IC chip on channel A & B and looks good a couple caps read a little high but ok i purchased new IRFB4227PBF and IRS20957STRPBF just incase I’ll replace the fets and the driver IC’s do you guys think it’s just a bad IRFB4227PBF I also had a Quick Look at the components in the power supply section and I think the power supply is ok looked at the diodes resistors and capacitors and couldn’t find anything I don’t want to risk turning it on and causing more damage am I on the right track hopefully it’s just the fet but I’ll replace all 4 fets and the 2 drive IC’s anyway
Cheers Ricky
