It has a manufacture date of 06/02/05.
It looks identical to this:
It has made the noise ever since i've had the UPS which is about 6 years. It has had new batts installed during that time too.
Im guessing the freq of the sound is around 10khz or so.
The noise hasn't bugged me in the past as its normally been in a noisier environment (i've just moved house).
Thanks guys, ill pop the top off again later and have more of a poke around.
If youre interested, here is a serial data dump from it:
DATE : 2015-11-16 14:05:58 +1030
CABLE : Custom Cable Smart
DRIVER : APC Smart UPS (any)
UPSMODE : Stand Alone
STARTTIME: 2015-11-15 10:40:37 +1030
MODEL : Smart-UPS 2200
STATUS : ONLINE
LINEV : 246.2 Volts
LOADPCT : 17.5 Percent
BCHARGE : 100.0 Percent
TIMELEFT : 86.0 Minutes
MBATTCHG : 5 Percent
MINTIMEL : 3 Minutes
MAXTIME : 0 Seconds
MAXLINEV : 246.2 Volts
MINLINEV : 244.8 Volts
OUTPUTV : 246.2 Volts
SENSE : High
DWAKE : 0 Seconds
DSHUTD : 90 Seconds
DLOWBATT : 5 Minutes
LOTRANS : 208.0 Volts
HITRANS : 253.0 Volts
RETPCT : 15.0 Percent
ITEMP : 33.3 C
ALARMDEL : 5 Seconds
BATTV : 54.8 Volts
LINEFREQ : 50.0 Hz
LASTXFER : Automatic or explicit self test
NUMXFERS : 0
TONBATT : 0 Seconds
CUMONBATT: 0 Seconds
XOFFBATT : N/A
SELFTEST : NO
STESTI : 168
STATFLAG : 0x05000008
REG1 : 0x00
REG2 : 0x00
REG3 : 0x00
MANDATE : 06/02/05
SERIALNO : JS0523036976
BATTDATE : 18/11/11
NOMOUTV : 220 Volts
NOMBATTV : 48.0 Volts
EXTBATTS : 0
FIRMWARE : 654.12.I
END APC : 2015-11-16 14:06:21 +1030
