Greetings EEVBees:
--It just occurred to me that some of the projects I have been posting in "General Chat" actually belong in this category. Administration is welcome to move, if deemed necessary. I apologize for being thoughtless.
--Now, back on topic. I was given an Apple AirPort Router 1.8 A 12 V SMPS which was reported to have no output. I cut the 12 V output plug off of the SMPS and soldered it to a working 12 V linear PS, that solved the immediate problem. When I finally got around to checking the output of the SMPS, I found that it was putting out 12 V, and I surmised that it must be a cracked solder joint that was heating up and separating. I managed to cut the darn thing open, which was not easy or pretty, and with a jewelers loupe inspected it. Other than some uncleaned flux, I could find nothing wrong with it. So I sealed it back up using electronic silicone.
I then hooked it up to power resistors to draw the rated 1.8 A and placed the whole thing in a Pyrex plate. The first picture below shows that the PS is working but is sucking hind teat, and is unable to come up to the full V and A. And, the second picture shows the PS output after two minutes. It has gone completely bonkers and is switching on on off an jumping around like crazy.
--I opened the PS back up and cast a critical eye (see third picture below) to the small capacitor with the black mark on the top. At first I assumed that this was just a check off mark by a Sharpie like the one on the blue rectangular safety capacitor, but now I am not so sure. So I removed all three capacitors marked "Koshin", a brand unknown to me, and have ordered good known SMPS caps from Digi-Key. Also, more for my own edification, that any other reason, since when I open a non-working SMPS I am going to replace all but the largest Caps, I have ordered a Dick Smith Blue ESR Meter Kit.
--Your comments are humbly solicited, and I will report back after attempted repair and testing.
--Would someone please tell me how to move picture into the body of the text? Or can anyone tell me where to look for that information?
"Three weeks in the lab will save you a day in the library every time"
R. Stanley Williams 1951 -
Best Regards
Clear Ether
