Author Topic: Aquarium chiller/compressor/fan won’t turn off/ chills and chills and chills...  (Read 7466 times)
Offline SMdude
@SMdude it's the one WITHOUT the markings. Labeled on the board as D1. The one that's closest to the thermistor connection on the board. :)e I get it now. I think. ...
@SMdude I got the relay correct thiugh right?
Yes, that is my guess going by how the board is laid out.
But you must confirm this by looking to see where the trace that connects the red wire to the relay goes, it should go to that relay.
Offline Airwalk1616Topic starter
Well, the solder joint connects it directly from the red spade connection to the NO terminal of that relay. Are there smaller printed traces you’re referring to that I need to check?
Offline SMdude
Nope, that is it. That is the relay you need to change.
so I’m a actually right??
Shown pretty well here.
Officially fixed guys!  Working like it's supposed to! Thanks for all the help!!!!
@SMdude especially you my friend. You help3d me outnimmensly. It’s so rewarding to diagnose the issue and have fixed it myself. Feels great..
The following users thanked this post: SMdude
Offline SMdude
Awesome, I'm glad you got it working again!
It is really empowering to be able to fix stuff yourself, but I would reccomend learning more on low voltage stuff until you really start to know what you are doing. High voltage isn't really forgiving!  :-BROKE
Cheers!
