What's next to fix is this AR subwoofer. It was built around 2001 and it seems to play pretty well but when it is turned off, a "thump" is heard a few seconds later. There was no signal present at the input of the subwoofer prior to.
I'm going to open it up and check if something looks loony
The first thing I did was measure the load of the 8" speaker. It measures around 4 Ohms. The speaker appears to be in very good condition too:
The plate amplifier itself was blanketed with fiberglass insulation. I brushed and vacuumed it out. Maybe, this isn't the type of sound deadening to be using inside of a "vibrating" speaker
I turned on the subwoofer while it had no signal being sent to the inputs and I measured ~70mVDC at the speaker terminals using my DMM:
I then sent a 20Hz sine wave into the plate amp and my oscilloscope measured a near perfect output from the subwoofer. If I raised the amplitude, I could literally bounce my Hakko soldering iron off of the bench!
I'm going to search the web for a schematic and see how the components are arranged. I do see some quality caps like Jun-Fu and G-Luxon inside too
I also made a video of the way the subwoofer acts when it is shut off:
