Author Topic: artesyn NLP250R-96S24J  (Read 1127 times)
Offline hitecelecTopic starter
  • Country: in
« on: September 15, 2021, 08:27:41 am »
hello Folks
SMPS with burnt smd component. Does someone have a schematics
thanks in Advance
Regards
Anand
Offline CJay
Re: artesyn NLP250R-96S24J
« Reply #1 on: September 15, 2021, 10:15:50 am »
Post pictures of board and components
The following users thanked this post: wraper
  • Country: in
« Reply #2 on: September 15, 2021, 01:20:47 pm »
Hello
Ok. will do
  • Country: in
« Reply #3 on: September 16, 2021, 10:35:01 am »
Hi Cjay
PFA
regards
Anand
  • Country: in
« Reply #4 on: September 16, 2021, 10:39:25 am »
Hi Cjay
PFA
  • Country: in
« Reply #5 on: September 16, 2021, 10:40:55 am »
Hi Cjay
PFA
  • Country: in
« Reply #6 on: September 16, 2021, 10:42:09 am »
Hi Cjay
PFA
Offline NiHaoMike
    • Facebook Page
« Reply #7 on: September 17, 2021, 12:57:21 am »
If it's not easily fixable, just replace the whole module. 24V power supplies of that size are commonly used in 3D printers.
Offline perieanuo
« Reply #8 on: September 17, 2021, 08:43:46 am »
the pwm ic is readable, start from his datasheet and put the schematic from your pcb on paper, takes the same time like searching 2 hours for a schematic  you may never find (if you didn't get it in 2 clicks, that means you gotta reverse engineer the thing, if you aren't attracted to this goooood idea, just be consumer and buy another one, like others suggested
i vote for reverse engineering, you'll learn more
changing is the last resort for lazu and stu)pid ppl, yep let's throw anything at the bin and buuuuy another  :-DD
Offline perieanuo
« Reply #9 on: September 17, 2021, 08:49:44 am »
seems like L4981B pfc chip
The following users thanked this post: CJay
  • Country: in
« Reply #10 on: September 18, 2021, 05:31:26 am »
Agree. need to take time out and try
thanks.
