Hello?
I would like to ask about the 80W, AC 110V input, DC+5V, -5V output SMPS (shindengen CY05010) fault repair.
symptoms of a breakdown
1. There is no output of +5V voltage. -5V output available and voltage control is possible. If the voltage control volume is raised, the power LED is turned off, resulting in a voltage drop to -1.8V, and if the volume is reduced, it will not recover to its original voltage. (Is it a normal function?) It will be restored only when the power is completely turned off and on.
2. It is thought that the output is achieved only when the RC (REMOTE CONTROL) terminal is SHORT, but when SHORT is made, the power LED is turned off and all voltage outputs are not possible.
3. The voltage at the output end (+5V, -5V) is SHORT state from the beginning. In order to find out the cause, I tried to separate the capacitor, diode, FET, etc., but it is still SHORT state, and finally, when I separate the 8 ohm cement resistance connected between +5V and -5V, SHORT state disappears. (This is cement resistance that was constructed during the initial design, so this can't be a problem, right?)
Attached is the picture, please give me your opinion. I thought it was a simple defect, but it's not easy.
Thank you.
